Hotpoint Cond. Dryer | TDWSF83EPZ(UK) | Won’t heat on sensor dry
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Cond. Dryer | TDWSF83EPZ(UK) | Won’t heat on sensor dry
  • #103668
    neon_3SP_glow
    Hotpoint Condensing Tumble Dryer.
    TDWSF83EPZ(UK).
    859991008660.
    Machine will dry on a timed setting. But, none of the sensor settings generate any amount of heat/drying.
    Any tech or experience on this, please?
    It’s not a model I am familiar with.
    I suspect the main control module is faulty – the method of reading moisture appears to be a metal strip inside the drum below the door line. Presumably, this is acting as the old carbon brushes would, to pass a small voltage between the drum and sensor strip. Cant really see how that can go faulty aside the module.
    Cheers!
    #494139
    neon_3SP_glow
    No love for this one!?
    The module is almost £190.00.
    Considering biting the bullet and referring to SlopPoint.
    #494140
    Hollytree_Technical
    Apologies – I missed this one but if you want to provide me with an email address then it appears that I have the service information saved for this one.
    Jem
