Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint condenser dryer TCFS 83B
- This topic has 6 replies, 2 voices, and was last updated 3 years, 8 months ago by
Shroppyfly.
July 23, 2022 at 4:49 pm #101036
Shroppyfly
ParticipantHello Experts,
Perhaps a foolhardy thing i’ve done but in my possession is a less than 2yr dryer, the power on light comes on but so do the empty water light and the inside lint filter clean light so thats the top 2 lights above start button, i’ve cleaned the water pump and lint filter, but now my arthritis is playing up bigstyle in my hands [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/wave.gif”}[/IMG2] , can anyone assist me in what it maybe ?Thanks in advance
JamesJuly 23, 2022 at 6:53 pm #483109electrofix
Moderatorcheck the overheat stat on the element
July 24, 2022 at 8:35 pm #483110Shroppyfly
ParticipantHi Dave, so it has 3 stats in a row 2 flat disc ones and the the one with a spike type probe on it I presume that’s the one your saying check, multimeter says no continuity on that one but ok on the other two, so is that likely to be the issue?
Cheers JJuly 24, 2022 at 8:49 pm #483111electrofix
Moderatorone of those stats is an NTC which is a resistor that changes with temp
if you look for a higher resistance reading then you will find its ok
the other 2 you say you get zero ohms or there abouts which means ok
the next thing to look at is continuity of the element itself and the float in the pump chamber to make sure its not stuck or it may be full of water and cant pump it up
July 24, 2022 at 10:04 pm #483112Shroppyfly
ParticipantUsed the multimeter on lowest ohm setting the two flat stats have the same low reading which I take to mean continuity i.e. Ok? The other one with The point probe the mm didn’t register anything am I doing understanding it right? I’ll check the element for continuity tomorrow
and cleaned the pump area was pretty good anyway as dryer Less than 2yrs oldJuly 24, 2022 at 11:41 pm #483113electrofix
Moderatordid you set the multi meter on a higher scale
poss expecting 3 to 50 K ohms
August 16, 2022 at 6:13 pm #483114Shroppyfly
ParticipantAh apologies dave , i sorted it, not been very well:( or id have replied earlier cheers
