Does any one have the fault codes for the above and how to read them. I have all five horizontal lights flashing and the two lower vertical lights on. Rear stats, temp sensor and heater are good.
Thanks,
Mike.
Yes, I have checked the resistance of the NCT, so that is the temperature side checked. I think the bottom light is not used in the codes which will make it an F1 fault which is the motor constantly running. The motor still runs when the lights flash which points to F1. The board is beyond what the machines worth so it looks like a sad end to a nice machine. Thank you for the help though..
Mike.
