Hotpoint condenser pump which 1 part number
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint condenser pump which 1 part number
  • #91992
    garn
    hi. cant seen to locate the correct pump for this model theirs a change in pump looks smaller than the ones i have on board the van.
    HPT SUTCD97B6PM9(UK)
    S/N 9586805500
    IND CODE. 701174143
    ANYONE KNOW WHICH IS THE CORRECT PART NUMBER THERE A CHOICE OF 3 CANT MAKE THEM OUT.
    THANKS GARN
    #449959
    don
    Re: Hotpoint condenser pump which 1 part number
    garn wrote:hi. cant seen to locate the correct pump for this model theirs a change in pump looks smaller than the ones i have on board the van.
    S/N 9586805500
    Hi Garn
    The only model close to yours on Hotpoint database is the SUTCD97B6PMU commercial code of 086808 and the pump is C00306876.
    Your commercial code looks to be 86805 which is not recognised by Hotpoint.
    Don
    #449960
    garn
    Morning Don Thanks for the reply late getting back to you 58 years young and slowing down big time.
    info
    the original pump is on the left of the pic pattern rite hand side.
    slight difference original SUT MODEL in the body mount is different and the connection block is shorter on the appliance is this a whirlpool based pump the appliance is just under a year old and used as a semi commercial use no warenty.
    sorry to be a pain GARN.
    #449961
    don
    Hi Garn
    You missed an all important 8 out in your original post 95868085500 The pump part number in my last post is correct 8) 😆
    Don
    #449962
    Also got the serial number and industrial code mixed up in the first post as well. 😉
    #449963
    garn
    Ok soory for the mox up working of a mobile cant see so good its Age related
    Paul
    #449964
    garn
    hear i am again i must be confused sum how C00306876. which iv been given also i have the alternative on board the van PMP 992 Connect which looks exactly as C00306876. see pic but does not fit.
    if you look at the outlet of the pump rite hand side pic where the black pipe goes is totally different from C00306876. and does not fit the body mount.
    #449965
    garn
    Hear it is Amazon
    https://goo.gl/images/t4KmKT
