Re: Hotpoint condenser tumble dryer making squeaking noise
Thank you for the reply, I will do as you say, if the bearing is worn, do I replace it and is it an easy job? further to what I wrote earlier I removed the condenser unit today to clean it and noticed at the back of the dryer a large amount of water and fluff, I scooped all this out and cleaned the filter, now I’m worried the water isn’t being pumped correctly, although there always seems alot of water in the water container, any ideas?
