Hotpoint condensing dryer – FTCF87BGG – error code e04
Home Forums Trade Technical & Spare Parts Forums Hotpoint condensing dryer – FTCF87BGG – error code e04
  • #99573
    twicknix
    I visited this dryer and quickly glanced at the error code list which suggests heating fault. I checked the stats including NTC which all checked out. Checked the elements which checked out.
    Other source suggests condensing pump which could be faulty?
    I am confused. The dryer did not produce heat until I took it apart to check the connections and it was producing heat when I left the property. Later on I got a call saying that the dryer is still showing e04.
    Any ideas?
    #476936
    this is what manual says
    twicknix
    I did check and it all working correctly even checked the ntc tolerance which is 100k at 25 deg. I checked the connections and all appears to be sound, I even tested each connector. Maybe there is a faulty connection by movement such as all is fine when I tested it then close it up which may have shifted the cable in a position to produce negative result?
    #476938
    but if you read it, it says “no rise in temp detected “
    Its really only saying the heater is not turning on but does not really give a clue as to why
    have you checked the board for relay solder problems ?
    twicknix
    I am due to return in the next few days to investigate it further and will get back to you on this. thank you for your help.
