Re: hopoint cooker
Model EW52P
thanks for scew extraction tip
this job was passed om to me as original engineer had not a clue on cookers..found mbc/rcd tripped as soomn as you switched on wall isolator..earth fault found on stat capi;;ary shorted to overheat TOC
re-route cables and fixed with cable ties
tested hob all fine
tested grill and top oven all fine
come to test main oven…heat calling light on with no switch turned, oven element glowing like the sun.. you can turn control on and fan kicks in
so why is oven element getting a feed with no control being set…can we say that the earth short has taken out oven stat also
any wiring diagram would be helpful
many thanks
Graham
