well the cooker switches on fine it will let you turn everything on even the main oven, the problem is only with the main oven, when the temperature is regulated with the door shut its fine, open the door without the temperature it doesn’t trip out it fine but have the temperature on and open and shut the door the RCD trips out ? any help
Re: Hotpoint Cred collection electric cooker tripping out he
hello thanks for advice it totally cured the problem but i think i caused a new one, i push the cooker in the slot all the way back there are two metal brackets and i push it into them and the RCD trips out any help ?
