Hotpoint/Creda Tumble Dryers
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint/Creda Tumble Dryers
  • #12607
    whiskeyjack6058
    Any of you guys out there fitted a stretch belt on one of the Hotpoint/Creda tumble dryers without a pully? Talk about needing bionic fingers. I was getting a bit upset doing the job at first but I found a fairly simple way to do it by dropping the motor off and re-fitting it with 3 longer screws, then replacing each individual screw back into place 1 at a time…. talk about having sore 4 arms though, got cuts all over them, you seem to feel them more on an evening…:cry:
    #150619
    Re: Hotpoint/Creda Tumble Dryers
    Read all about it, http://www.ukwhitegoods.co.uk/modules.p … int+dryers
    The special tool mentioned does work quite well.
    #150620
    I’ve said it before, and I’ll say it again – deep socket with extension bar, run the belt down, depress the extension, run the belt onto the shaft, remove socket, run the belt back onto the grooves. No expense, you’ve got this stuff in your tool boxes already.
    Easy peasy.
    Simon46
    And if you leave your sockets at home when doing an Indesit IS60V, unscrew the end off your maglite torch and use that instead!
    S.
    #150622
    pup
    hi
    i use small length of copper pipe 15mm
    #150623
    wilf
    special tool piece of cake but turn the drum so that paddle is at bottom so that tool can lever into depression
    ps try the new snapon belt onto croslee condensor dryer
