Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint & Creda Washing Machine Drum Paddle V2 Help pl
- This topic has 15 replies, 5 voices, and was last updated 15 years, 7 months ago by
stabiloboss.
September 9, 2010 at 9:25 pm #57146
stabiloboss
ParticipantHotpoint & Creda Washing Machine Drum Paddle V2 – some advice please
I am trying to fit a replacement drum paddle to an Hotpoint BWM129 – I have got the right part it is same as the one broken – I can see the 6 lugs which I assume you alight and slide up – not sure the purpose of the metal lug on the drum which is upright – does this need to be pushed down ..or is it a case of just align the lugs and push home – any advice please
September 9, 2010 at 9:44 pm #330012iadom
ModeratorRe: Hotpoint & Creda Washing Machine Drum Paddle V2 Hel
Sadly this machine is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit, just do your best, there is apparently a special tool with a hooked end to lift the tab into place after refitting.
I’m intrigued by your reference to V2 lifters. The original Hotpoint machines have V1,V2 & V3 lifters but there is only one type of lifter for this Indesit machine and it is totally different to any V2 lifter.
The correct part number is C00064789
September 10, 2010 at 11:27 am #330013stabiloboss
ParticipantRe: Hotpoint & Creda Washing Machine Drum Paddle V2 Hel
Thanks Iadom for you help much appreciated – like I say the part supplied is identical to the orginal (yes part supplied in an Indesit wrapper)
So would I push down the metal plate first and when fitted the new part into the 6 slots try and pull it back up right with something..
September 10, 2010 at 11:32 am #330014iadom
Thats the best thing to do, what was the part number on the wrapper?
May 24, 2014 at 12:12 pm #330015PFM
ParticipantRe: Hotpoint & Creda Washing Machine Drum Paddle V2 Help pl
I have the same problem – tab needs to be pushed down to slide lifter into place, then needs pushing up to hold lifter. Can’t see any way to get to outside of inner drum to do this, and near impossible to do it through one of the holes in the lifter. Any help appreciated.
May 24, 2014 at 12:33 pm #330016Martin
PFM wrote:– tab needs to be pushed down to slide lifter into place, then needs pushing up to hold lifter.
Nonesense, you slide the drum lifter over the raised tab which then locks it in position!May 24, 2014 at 12:38 pm #330017PFM
Maybe on some, but not on mine. Lifter will not slide into place with tab raised.
May 24, 2014 at 12:44 pm #330018Andy jones
Then you’ve got the tab raised too high. Although I sometimes put a small screwdriver though the hole to raise the tab a little
May 24, 2014 at 12:57 pm #330019iadom
ModeratorRe: Hotpoint & Creda Washing Machine Drum Paddle V2 Help pl
Martin wrote:
Nonesense, you slide the drum lifter over the raised tab which then locks it in position!Wrong, that was the method with the original Hotpoint drum lifters, these are the awful Indesit ones, the tab is supposed to be lifted up ‘after’ the lifter is pushed back into place.
If you are careful you can twist the tab at a slight angle and raise it very slightly, you may then just get it to lock. The official ‘special tool’ that is supposed to be used to lift the tab is impossible to use as it will not fit through the holes in the lifter when it is fitted to the drum.
I use an old, broken Hotpoint WM 1601660 rear spring with a small hook formed at the end.
If the tabs break off then the official fix is to drill a tiny hole at the front edge of the lifter and insert a small, stainless steel screw.May 24, 2014 at 1:00 pm #330020PFM
Thanks, iadom – that is the machine I have. So, how does one perform this particular magic trick?
May 24, 2014 at 1:03 pm #330021iadom
Edited my post. 😉
May 24, 2014 at 1:06 pm #330022iadom
If you read THIS thread you will see just how useless the official special tool is. :rolls:
May 24, 2014 at 1:12 pm #330023Andy jones
Don’t you just love indesit / hotpoint these days 🙁
May 24, 2014 at 1:16 pm #330024PFM
Many thanks. Think I’ll make my own ‘special tool’ from a wire coathanger, failing that will get out the drill.
May 24, 2014 at 1:24 pm #330025iadom
If you do use the drill method then take great care not to drill through the outer drum and make sure any screws are stainless steel and short. 😉
TBH I think that it would have to be a very thin wire hanger, most of them would be too thick to fit under the tab when it is flat to the drum.
