Re: Hotpoint CTD 00P Condenser Dryer
Well it seems holding ones breath does actually help so thanks for the response mate. I only broke one tab taking it apart and guess what ! the problem was that the rubber band which poses as an impeller on the pump was broken. I cannot believe that this machine depends on a rubber band for continued operation and a rubber band that cannot be purchased separately either! It must cost around 10 p to produce one of these and yet I am expected to spend £24.00 on purchasing a new pump now. Actually, if you have a hot glue gun and a steady hand( holding the breath helps here too) then it can in fact be repaired. Not sure how long it will run for but its working fine now !!!.
