Hotpoint CTD 80 F12
  • #44174
    Turbo
    This dryer had a no heat fault, would run but no heat, on inspection I found that the thermistor had gone. After changing the thermistor and thermostat kit it still failed to heat. Checked the thermistor and once again it had failed. Put in another set of stats/thermistor thinking that the first set may have been faulty and now it will not run and error code 12 appears in the display window the moment you turn it on 😥
    Have also tried a heater with the same result 😥
    Has anyone else had this problem.
    Thanks Graham
    #280051
    helo_75
    f12
    non communication between pcbs
    try unlugging all the plugs from the pcb, and give em all a squeeze, and hope it works
    #280052
    Turbo
    Re: Hotpoint CTD 80 F12
    Thanks Helo 75 I will check that out.
    Graham
