Hotpoint CTD00
  • #66443
    pegasusk7
    So how do you stop water building up within the heater cover on a CTD00?!
    Phil
    #364190
    preggy
    Re: Hotpoint CTD00
    Hi Phil
    This is commonly the pump failing.
    It will work fine when you test it but through full dryinmg time they fail.
    Replace the pump, it comes as a kit complete around £28:00
    Cheers
    David
    #364191
    Rograbbit
    Re: Hotpoint CTD00
    Some of these did have a modified rear cover with a drilled hole and a felt pad on the outside. The Hotpoint guys will tell you more.
    A bit heath Robinson but what do you expect…..
    #364192
    pegasusk7
    Re: Hotpoint CTD00
    The pump was actually replaced beginning of the year so wouldn’t be expecting any problems there but then again it’s Hotpoint. I found one reference online to a modified cover plate yet the parts illustration I have seems to show an identical item to that already fitted, ie no hole or pad. Think I’ll wait to see if there is any reoccurrence!
