Hotpoint ctd00
  • #39072
    simonb
    customer complaining of no heat fault, he changed thermostats himself and got them wrong way round, so i corrected them unblocked condensor unblocked filter and gave it good test out for 20 mins. when i left it seemed to be working fine, next customers back on the phone complaining of same fault no heat?
    either its overheated and the one shot has gone or as before stats ok and no heat fault? any ideas?
    these machines dont seem as straight forward as older condensors with green stat kit on, i hate the barmy way the element assembly is screwed to backplate.
    #261195
    Re: Hotpoint ctd00
    A badly blocked condensor is a common cause on these machines. Its a real PITA to clean out now it has the plastic front on it although if it has the two screws in the side it is possible to remove the front to clean but it is definitely not user friendly. 😥
    helo_75
    i think id be changing the capacitor
    commonly, they break down under load after about 30 mins, and the stats pop out
    hope this helps?
    #261197
    simonb
    Re: Hotpoint ctd00
    Thanks jim already cleaned out condenser i agree can be a pig to clean
    ill give the cap a try, how does it effect the stat to trip out on overheat?
    #261198
    Re: Hotpoint ctd00
    …………Because the motor stops, hence no fan, stat pops! 😉
    #261199
    helo_75
    exactly!!!!!!
    #261200
    simonb
    Re: Hotpoint ctd00
    Silly me! 😳
