Hotpoint CTD00 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint CTD00 This topic has 6 replies, 3 voices, and was last updated 17 years, 6 months ago by ChrisR. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts October 7, 2008 at 8:34 pm #40039 ChrisRParticipant Hi guys. Problem with this is water collects in base instead of container yet everything appears ok. It works fine when i`m there but when she uses it again the clothes are damp and hot with water in base. I`ve had pump and float apart,cleaned and refitted.No blockages anywhere. Any ideas. 😕 . Ta. Chris. October 7, 2008 at 9:38 pm #264520 iadomModerator Re: Hotpoint CTD00 Intermittant pump failure?? October 7, 2008 at 10:04 pm #264521 helo_75Participant and you have cleaned out the hole between the condenser housing and the pump? October 8, 2008 at 6:36 pm #264522 ChrisRParticipant Re: Hotpoint CTD00 Thanks lads 😀 October 13, 2008 at 8:24 pm #264523 ChrisRParticipant Re: Hotpoint CTD00 Where abouts is the drain hole from the condensor housing to the pump chamber?. 😕 . October 13, 2008 at 8:35 pm #264524 helo_75Participant take the pump out the hole is on the very left hand side at the bottom… i have an old belt, cut in half , which is perfet to shove through the hole when you push it through, youll know if it was blocked, because water will flow i then take out the condenser and put my arm down and remove the fluff that was blocking it, cos it usually washes back hope this helps? October 13, 2008 at 8:58 pm #264525 ChrisRParticipant Re: Hotpoint CTD00 It certainly does. Your a star. 😀 Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
