hotpoint ctd00 belt keeps snapin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint ctd00 belt keeps snapin
  • #72431
    andysam
    hi ive replaced the frond and back bearings on this machine and the belt keeps snappin the belt i was told for this machine is a pol 91. any ideas would be appreciated.
    #384500
    repman
    Re: hotpoint ctd00 belt keeps snapin
    check the timer make sure it does not snatch the belt when reversing,you may have to watch it for quite a while
    #384501
    You could always try a gen belt, C00116358 but they do go through belts faster than the old double jockey pulley dryers.
    Is the black plastic pulley in good order on this machine?
    #384502
    andysam
    worn slight on one side cheers
    #384503
    I would change the pulley and fit a gen belt, most of the belts I have changed on these recently have had broken or badly worn pulleys.
    #384504
    madangler1
    I find one these once disturbed they can take some tweaking to get to settle and tune fine again.
    If a new belt is snapping its normally due to the drum seizing and the belt burns on the motor, when you did the rear bearing you may need to add a washer or two on the shaft to keep the drum forward enough to stay on the front bearings. Also if the rear seal is worn it won’t hold the drum forward enough to keep it on.
    I had one two weeks ago that took 4 visits to get rite.
