Re: Hotpoint CTD00 Condenser Tumble, tripping my power point
The only way to find the cause is to check with the correct electrical test equipment.
I have seen one or two with the elements down to earth. One cause of this is failing to keep the condensor clean, this leads to moisture build up on the elements. If your condensor is badly blocked the best way to clean it is with a hose pipe or pressure washer, after you have removed it from the machine of course.
Please remove the plug if you intend to investigate or, click the link in my sig to see if we have someone in your area who can help.
