Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint ctd00 heat fault ??
- This topic has 14 replies, 6 voices, and was last updated 17 years ago by
jasper.
March 11, 2009 at 3:20 pm #44136
jasper
Participanthi guys repaired plenty of these dryers ,this one has me foxed??
year /half old dryer , cust says no drying clothes??
eg, checked all the usual,ie, stats ok, heater ok, pump funtioning ok , no water damage at fan ok, checked with a full load of towells , set timer to 100 mins, timer completed cycle,but!!!..load was half dried,and still a bit damp????….helllllp?? any suggestions?
jasper.. 😳March 11, 2009 at 3:59 pm #279896iadom
ModeratorRe: hotpoint ctd000 heat fault ??
Moved you to Trade Technical, 😉
I assume you have made certain the condensor is clear?
March 11, 2009 at 8:58 pm #279897leavemetogetonwithit
ParticipantRe: hotpoint ctd000 heat fault ??
Had a timer give a no heat fault on a similar machine. Contacts inside timer were burnt. There was no visible sign on the exterior of the timer.
Mike.March 13, 2009 at 4:19 pm #279898jasper
ParticipantRe: hotpoint ctd00 heat fault ??
cheers iadom, yes checked everything ,including , condenser???
just have to persevere!!!
jasper.March 13, 2009 at 4:22 pm #279899iadom
ModeratorRe: hotpoint ctd00 heat fault ??
Have you actually changed the stats, a long shot but the cycling stat could be failing.
March 13, 2009 at 4:22 pm #279900jasper
hi leveme……withit, suppose ill have to spend some money and order a timer?…
thanks for your input
jasperMarch 13, 2009 at 4:27 pm #279901jasper
hi iadom yes i will change the stats , before i go ordering a timer,
although a long shot,[exscuse the pun]….
cheers jasper.March 13, 2009 at 5:30 pm #279902DAGAV
Is the High heat switch working, could be only half the element is energising?
March 13, 2009 at 7:58 pm #279903iadom
Good call, forgot about that. 😳 I have seen that on more than one occasion.
March 13, 2009 at 8:01 pm #279904lerch
use a temp probe and check the temp on half heat and full heat. Approx 60c on 1/2 and about 100c on full. 😀
March 13, 2009 at 8:46 pm #279905iadom
I just plug my little digital meter into the wall socket then plug the machine in that and watch the current usage. 8)
March 23, 2009 at 7:25 pm #279906jasper
hi guys, thanks for all your replies,re this !!!!?? c/dryr
i,m pleased to announce, !!! success at last,
eg , ordered stats!!, didnae work!!, last resort, ordered,time, and guess what!!?, didnae need the damn timer,?? as on removing the said part!!!, i came accross, a poorly crimped lead,eg to heater!!!!!. re-crimped,and tested ok!!!!
one to keep an eye out for the future guys
jasper 😆March 23, 2009 at 10:38 pm #279907Specialist01269
iadom wrote:I just plug my little digital meter into the wall socket then plug the machine in that and watch the current usage. 8)
Hi Jim: Sounds like a good piece of kit, any idea where I can get 1?
Thanks: Andy.March 23, 2009 at 11:29 pm #279908iadom
ModeratorMarch 24, 2009 at 8:12 am #279909Specialist01269
Thanks jim: On order.
Regards: Andy. 🙂 -
