Hi all,
As above, I have a Hotpoint CTD00 which only heats up on the high setting.
I’ve checked the thermostats and elements for continuity: all good.
The heat switch on the front appears to be operating properly, as in it has continuity on the “high” setting and is broken on the “low” setting.
I’m at a bit of a loss really as to why it won’t heat up. Condenser is clear, fluff removed etc.
Any ideas? Happy to provide more information if it helps.
Thanks.
B
