Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint ctd00g dryer
- This topic has 7 replies, 3 voices, and was last updated 20 years ago by
hilly.
March 27, 2006 at 6:21 pm #16697
hilly
Participanti went to this one it had a worn jockey wheel so i replaced wheel,belt and felt band around door opening (felt was streched & out of shape) i got it all back together(after a bit of a fight with stretch belt. wot a nightmare!!!) but its noisey where the drum is rubbing on plastic rim at the front the customer said it has always been noisey, do i need to replace the two nylon guide wheels under drum front (they look ok) or is there a modification for these machines it looks like original fault and this one is due to stretch belt putting pressure on everything
thanks paulMarch 27, 2006 at 6:33 pm #171092iadom
ModeratorRe: hotpoint ctd00g dryer
There is a modification kit, it involves removing the two drum support pulleys and replacing them with the original bearing pads, includes seals and a few other bits.
Part No: 1703080.
March 27, 2006 at 6:34 pm #171093johnnyj
ParticipantRe: hotpoint ctd00g dryer
Yup part n/o is 1703273 comes with thinner belt bearing pads and a bronze rear bearing you lob the support wheels away and fit all the bits.
March 27, 2006 at 6:36 pm #171094iadom
johnnyj, has that part number changed, I used a 1703080 a couple of weeks back. It is also half the price of the one you posted. 😕
Although Partfinder only shows it as the rear shaft. ❓
March 27, 2006 at 6:41 pm #171095hilly
thanks iadom & johnnyj i guess one of those kits will do the job
thanks again paulMarch 27, 2006 at 6:46 pm #171096iadom
Stick with johnnyj for now, his information is ‘warmer’ than mine. 😉
March 27, 2006 at 6:48 pm #171097johnnyj
The 1703080 is used on the vented dryers, and the other is the mod for removing the support wheels on condensor dryers which caused excessive noise, but the parts in the 1703080 kit are mostly the same minus the belt.
March 27, 2006 at 6:53 pm #171098iadom
Ah, I see, it was the lack of a , in your first post between belt & bearing pads that threw me. 🙂
As the kit I used was on a condensor dryer and is listed at around £9.00 as opposed to the £18 + of the other kit, I know which one I will be using for now. 😉
