Re: hotpoint ctd00p
If there is no motor action and no heat then it could be caused by several faults, control timer, faults preventing the motor from running that have caused the safety stats to trip, etc. Checking with the proper electrical test equipment and if needs be a wiring diagram are required.
The wiring diagrams are under manufacturers copyright, it may be wise to see if we have someone in your area who can assist you, try the link in my sig.
Please remove the mains plug if you intend to proceed yourself.
