Hotpoint CTD00P
  • #33052
    7390ROBERTS
    Hi can anybody help me out please. The machine gives a grunting sound when the drum changes direction so am thinking front bearing pads machine still runs so customer wont let me strip it down till i get the parts have looked at the rear bearing and its ok. is there anything else it could be other than front bearing pads.
    Could you please give me the part number for the pads think i will start with them anyway then see what happens i get inside it.
    Thanks Bob
    #237265
    helo_75
    depending how old it is, it could still have the wheels on the front
    the kit (which contains all the front pads/seals aand a new belt) was originally part number 1703273
    im sure one of the guys will give you the updated number, and id change the impellor while i was at it
    the idea is to take the wheels off and replace them with front supports
    other then the wheels and the fan, they arent always that noisy… unless of course the drums catching on the back panel, then it will need a new style drum with a different profile, but then your into serious money
    can check that while the drums out, you can visibly see where the drums been catching.. originally, hotpoint put a sticky pad over it to try and quieten it down , but the real cure is to fit a new drum
    phew!!! hope this helps!
    #237266
    7390ROBERTS
    Re: Hotpoint CTD00P
    Thanks for that info mate will be usefull to me. But I have since learned he has had it to peices himself so not going to do the job now I dont like it when that happens you never know what they have done could end up costing me money!! Thanks again helo and have a nice xmas
    Cheers Rob
