Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Hotpoint CTD00P Fans
- This topic has 11 replies, 5 voices, and was last updated 16 years, 8 months ago by
Twoten.
July 22, 2009 at 2:36 pm #47269
Twoten
ParticipantCan anyone provide the part numbers for both the fans that would fit the above condenser dryer?
The other numbers on the machine where 95313490000 and 612201201 I understand there are 2 different versions of the outer fan, the one on the machine fits on a splined shaft held in place by a corbin spring clip.
Thanks,
Keith.
July 22, 2009 at 3:38 pm #292905iadom
ModeratorRe: Hotpoint CTD00P Fans
Rear fan. C00226347
Front fan. C00199451 After serial number 60907 0001
Jim.July 22, 2009 at 4:08 pm #292906Twoten
ParticipantRe: Hotpoint CTD00P Fans
Thanks Jim,
much appreciated.
July 31, 2009 at 10:08 am #292907Twoten
I just received the fan, the motor this fits on had a splined shaft.
Do you know if the inside of the fan should have splines in the moulding to match and prevent the fan from spinning on the shaft?
Thanks,
Keith.
July 31, 2009 at 2:09 pm #292908iadom
Not sure, I have a C00207723 fan which is for the earlier model, this is smooth on the inside.
Not seen a C00199451 TBH.
August 24, 2009 at 2:58 pm #292909geoff1
The C00207723 fits onto a splined shaft.
Just to confuse matters I have been speaking to qualtex to day as the fan blade I received for a C00207723 is now C00095599 which is only 7cm across the width instead on 10cm.
They confirm that this is now the replacement part
Geoff
August 24, 2009 at 3:32 pm #292910iadom
Perhaps as well, I fitted a C00207723 last week and it was a very easy push on, not very tight at all. 😥
August 24, 2009 at 4:17 pm #292911geoff1
It looks so small within its housiing compared to the original. Had a look at connections and they are showing the white fan now with note to say it is 3cm smaller. Hope it can shift the air needed to the condensor.
Geoff
March 5, 2013 at 2:40 pm #292912oakleyjo
I have a CTD00P in which the impeller fan is black and ~100mm in length. Can’t find anything matching that anywhere. Does anyone know where to get this length impeller fan, or whether the smaller fans that are available are a correct replacement? Service Ref number on the machine is 95313490000 608050037
Thanks,
JonMarch 5, 2013 at 4:58 pm #292913iadom
No mention on Partfinder of the larger 100mm fan, C00207723 being superceded with the shorter one but that may now be the case.
March 5, 2013 at 9:33 pm #292914madangler1
They reduced the length of the fan because after time they had a tendency to go unbalanced because they are only supported at the one end and cause the whole machine to vibrate badly, they replace it with the shorter version that does not suffer from this problem
Drop in airflow was so negligible it was not a problem
As for the new ones being loose wrap some insulation tape on the shaft and fit the new fan with a small hammer tapping it on and refit the clip, won’t move again 😉So if you ever get one that’s vibrating very loudly replace the front fan, see a few of them.
March 6, 2013 at 9:33 am #292915oakleyjo
Thanks for the info. The one I have is vibrating badly so I will replace it with the shorter one now I know it’s ok to do that.
Thanks again,
Jon -
