hotpoint CTD40 2nd question added
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint CTD40 2nd question added
  • #39299
    hearbear
    The water container light on the above model is flashing and not heating. The container is empty and the condenser is clear .
    Any help would be gratefully accepted.
    #261963
    helo_75
    thatll be a CTD40 then
    the pumps faulty
    located at the back, in the grey housing
    plug out if your checking
    #261964
    hearbear
    Re: hotpoint CTD40
    Corrected to title to correct model thanks for a quick reply will check today.
    #261965
    hearbear
    Re: hotpoint CTD40
    Stripped the pump ass of this afternoon and found the rubber band paddle burst super glued back on and seems to be working thanks for that.
    2nd question now there appears to be something between the drum and the outer housing is there a simple way to remove ie tipping the machine to a position to let it drop down to the condenser?
