Have low heat on all settings have tested heating elements ok, the two black stats are fine but the white stat is open circuit, not sure if this correct as this goes to pcb.
could anyone please let know as I feel this may be the fault.
Cheers John.
Hi: Rear NTC should read approximately 500 Kilohms at room temperature (20 deg c) also check the wiring between thermistor & board as this has a habit of going o/c.
