hi,went to this t/dryer today not heating fault.replaced rear stats which were o/c,but the fault code lights are still saying open rear ntc ,any suggestions regards tedd
Check connector J4 on main PCB, check NTC it should be about 500 Kilohms at room temp (20 deg) when checked at the NTC with the wires disconnected, Check for faulty wiring between J4 & the NTC, If NTC shows out of spec replace with correct type NTC, as Jim said 2 types available & they are definately not interchangeable, if all of the above checks out Replace main control PCB.
