Hotpoint CTD40 Condenser Dryer – Tripping my electricity!!! Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint CTD40 Condenser Dryer – Tripping my electricity!!! This topic has 2 replies, 3 voices, and was last updated 16 years, 5 months ago by The_Muher. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts October 19, 2009 at 7:58 pm #49444 The_MuherParticipant Hello all. Having a problem with my dryer. The Dryer comes on without a problem and I can select a programme but when I press the button to start the programme, the machine begins run the programme but before it starts to run the fuse goes and cuts the electricity. Any ideas what could be causing it?? Any help and suggestions appreciated. Thank you! October 19, 2009 at 8:38 pm #299928 helo_75Participant the heaters wet take off the rear banjo shaped panel.. if water comes out, then dry it all out with a hairdryer the water is normally there because the drain hole to the pump is normally blocked ( the grey box bottom right ) plug out if your looking ! October 21, 2009 at 7:03 am #299929 twinsparkParticipant Re: Hotpoint CTD40 Condenser Dryer – Tripping my electricity make sure pump is running after. also when heater is dry if still does the same you will need a heater, keep condenser clean too 😀 Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
