Hotpoint CTD40 dryer – water leak around water container
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint CTD40 dryer – water leak around water container
  • #43849
    goonergal
    Dryer was working and came to end of timer – clothes dry as normal.
    When I took out the water container to empty it there was a lot of water underneath. Container did have water in it as well.
    Container was emptied before this load and dryer was not overloaded. Any advice gratefully received!
    #278819
    hotpnt
    Re: Hotpoint CTD40 dryer – water leak around water container
    hi, easy to fix, the drain hole under the back of the water container is blocked,
    Plug out First
    Take the lid off, (2 screws at back)
    Remove the water tank/drawer
    There is a hole at the back where the tank fits, for overflow to run back to pump, this will be blocked causing the leak
    Nice, Easy repair
    #278820
    goonergal
    Thanks very much for your help. Will go and play with the dryer 😀
