This m/c works for a short time then the on/off led light starts flashing and counting from top to bottom the led lights on the left – (2,3 &4) start flashing too. The m/c keeps turning but no heat.
I can’t find any reference in Known fault codes – can anyone shed any light? the two toc’s at the rear read ok 🙁
F07 Lower element failure
Check security of module connector J4;
Test between pins 4 and 3 on J4 (approximately 48 Ohms);
If open circuit, test lower element and wiring between J4 and
the heater.
70802.0000, from this serial the one shot thermostat is wired into module if this operates the unit will appear dead
There are not two TOC’s, one is a cycling thermostat and the other is a one shot TOC. Some models only have a single TOC and NTC, the cycling stat has been taken off then put back in at least once.
