im having a nightmare with this machine i have pulled it into the workshop.the original fault was no heat and a prev “engineer” had been out and reset the toc using a pin 😯 .the fault then reoccured so cust asked if i would take a look.I found the toc o/c so ordered a stat kit which came as 3 stats which was strange as the original only has 2 so i matched and changed the 2.it now runs for a little while then faults 1,2 and 4 which is rear ntc.
Can anyone explain why 3 stats where sent but only space and wiring for 2 on the machine,serial 509210007.
thanks for the replies and the manual will have a peruse.my spares company who are hotpoint agents said there where 2 kits on this model and ser no and i have the correct one with 3 stats.nightmare
