Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint CTD40G condensing dryer completely dead
- This topic has 8 replies, 3 voices, and was last updated 15 years, 5 months ago by
neilcook.
November 1, 2010 at 8:33 pm #58503
neilcook
ParticipantAll basic items checked. Low insulation reading of 1.25 m ohms?
Door switch, float switch, circ pump, connections, heater etc all checked.On/off swtich dead as if no power to machine? Could it be main circuit board failure? Press switches appear ok on control panel can these play up?
Neil
November 1, 2010 at 8:35 pm #334728leavemetogetonwithit
ParticipantRe: Hotpoint CTD40G condensing dryer completely dead
R.I.F. checked?
Mike.November 1, 2010 at 8:42 pm #334729iadom
ModeratorRe: Hotpoint CTD40G condensing dryer completely dead
One shot stat checked?
Neutral is fed through the one shot on later machines, totally dead if this is O/C. 😉
R.I.F. ❓
November 1, 2010 at 9:01 pm #334730neilcook
Is the one shot stat the one above the door apeture just indside front panel? That was O/C when i checked it I’m sure?
If it has gone, does that mean another problem with machine or could it be overloading?
😛 RIF GOOD.
Neil
November 1, 2010 at 9:07 pm #334731iadom
No, the one shot is near the heater, the doofer at the front is an NTC so may appear O/C on a simple continuity test.
Testing the front NTC from the PCB connections should read 500kΩ at room temp.
There have been several changes, full serial number would help to be certain.
November 1, 2010 at 9:50 pm #334732neilcook
OK. Thanks for that. Will re-check.
Many thanks
Neil
November 1, 2010 at 10:09 pm #334733neilcook
Serial Number is 802210180.
CTD40G
Mod number95313610000I notice there is a 3 part stat kit available?
I’m sure she told me she had had it 18 months?
Neil
November 1, 2010 at 10:39 pm #334734iadom
That does have the neutral wired through the one shot.
The kit inlcudes three stats but you only need the NTC and one shot if it only has those fitted above the heater.
The cycling stat was on originally, then taken off, then put back again. 😥
November 1, 2010 at 10:48 pm #334735neilcook
Thanks, There are three stats above the heater on this machine.
Neil
