Hotpoint CTD40P No heat?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint CTD40P No heat?
  • #39292
    Nic_Collins
    It’s only blowing cold air through the drier and there’s a flashing power and time delay light. Have cleaned the condenser unit which was clogged with wet fluff but still only getting cold air. I suspect that the heating element has burnt out and needs replacing although I would have thought that there must be a thermal cut out which should have prevented this?
    Before I nip off to Ebay to buy the spares I’d appreciate any advice as to whether I’m barking up the wrong tree (knackered thermostat?) and am wondering if a DIY job is possible as Hotpoint want £100 to repair it!!!!!
    Nic
    #261945
    Nic_Collins
    Re: Hotpoint CTD40P No heat?
    Of course if I’d done a ‘search’ first I’d have been able to answer most of my questions!! It would appear that I need to try a thermostat kit rather than a new element, any DIY tips on disassembly and re assembly of the machine will be much appreciated!
    Nic
    #261946
    Plug out first, the heater and stats are behind the small back panel. Handle with care, the elements are very delicate.
    Nic_Collins
    Thanks, I’ll let you know how I get on!
    #261948
    Nic_Collins
    Well it’s fixed, a very simple job (except for the kitten playing with the screws while it was dismantled!) so thanks for the advice.
