Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint CTD40P Not heating
- This topic has 5 replies, 2 voices, and was last updated 17 years, 5 months ago by
blindman.
November 21, 2008 at 11:25 am #41212
blindman
ParticipantModel CTD40P
Serial number 707040221Seems (my daughter) has the usual problem with this machine.
Allegedly there are no lights flashing etc so hopefully this is a simple “stats” replacement.
Have read various threads and I need the
http://shop.ukwhitegoods.co.uk/Tumble+Dryer+Parts/Hotpoint/Thermostats/1703608+-+Hotpoint+Tumble+Dryer+Thermostat+Kit.htmlKit.
Question.
I have the back off the machine and have found only two “stats”
Do I need to change all three and where is the other one?Ta
November 21, 2008 at 4:18 pm #269146iadom
ModeratorRe: Hotpoint CTD40P Not heating
You have checked the stats for continuity first I assume.
There used to be three stats fitted, then they removed one in July 05 and then refitted it again in Jan 06.
According to the information I have the third or cycling stat was refitted after serial number 60109.00001 so yours should have three unless of course they have removed it again.
The kit will contain a one shot safety stat, a cycling stat and an NTC. If you only have two then you only need to replace the NTC and the safety stat.
November 21, 2008 at 4:41 pm #269147blindman
ParticipantRe: Hotpoint CTD40P Not heating
iadom wrote:You have checked the stats for continuity first I assume.
Thank you for the reply.
I will do a continuity check before ordering etc.
So if there were to be three stats then they’d all be in that back panel?
BTW
Both stats looked exactly the same with no dots or colours etc.Are the replacements easy to tell apart?
November 21, 2008 at 4:54 pm #269148iadom
When three stats are fitted they are all situated above the heater. Normally the one shot safety stat has a spot of paint on it, however if you remove them carefully and examine the under side ( don’t press the underside) you can identify the safety stat, if the base is concave then it has tripped and will not reset. The NTC has a solid base and is normally fitted to the right.
I do carry these items but I am off for a game of squash shortly. I will dig out a set and see if it is possible to identify which is which when I return. 🙂
November 21, 2008 at 7:50 pm #269149iadom
I’m back. 8)
In the kit there are two stats and an ntc. The ntc is obvious because it has a completely flat base.
The ‘one shot’ safety stat has a white spot on it and in most cases a tiny hole in the centre of the top side.
If your machine only has one stat and one ntc then you will only need to replace these two and discard the cycling stat.
HTH.
November 24, 2008 at 10:11 am #269150blindman
Thanks for the reply iadom
Hope to get it sorted soon.
