Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint CTD80 condensing tumble dryer
- This topic has 9 replies, 3 voices, and was last updated 19 years, 6 months ago by
Bernie.
October 12, 2006 at 3:16 pm #21637
Bernie
ParticipantJust been to a Hotpoint CTD80 condensing tumble dryer, serial 509220336 customer has fitted a thermostat kit to it him self.
only heβs not sure he fitted them correctly as it still donβt work.F13 Rear NTC open or short circuit
I have just read on this site that the kit 1703607 that he used has three stats in it, when I had a look I could only see just the two above the heater.
He did show me the old ones and the one shot had gone and there was only two in the box.What I need to know is which stats go where and how to identify which ones which.
I know one is a white dot and its been fitted on the left as you look at it, which I believe is correct.Bernie
October 12, 2006 at 4:35 pm #191966iadom
ModeratorRe: Hotpoint CTD80 condensing tumble dryer
I can send you a wiring diagram if you like. Personally, I would run a mile from this, I am wondering what the punter has done with the wires to the missing stat or ntc. π―
October 12, 2006 at 4:47 pm #191967Bernie
ParticipantRe: Hotpoint CTD80 condensing tumble dryer
Thank you for the offer of a wiring diagram that would be good.
I like to help people if I can and I am intrigued with this one
I know I’am mad!Bernie
October 12, 2006 at 4:48 pm #191968iadom
Will sort it later, time to make the tea now, 8)
Jim.October 12, 2006 at 7:37 pm #191969SDR
before date code 50712 which yours is the heater only has 2 stats one shot and cycling, after dc 50712 they used 3 stats. by the sound of it you will need to fit a module and eeprom. one thing though check condenser these block within about 2 weeks on this piece of sh, sorry i mean this little baby π let me know if need any more info as i franchise for hotpoint, got up to date partfinder.
October 12, 2006 at 7:42 pm #191970SDR
sorry got that wrong from dc 507120000 jul 05 the cycling stat was removed . π³
October 12, 2006 at 7:44 pm #191971iadom
Thanks for that info SDR, absolutely no mention of two stats on the latest, trade version of Partfinder that I can see, no mention of it in manual 5412719 either. π₯
EDIT, just seen your last post. Partfinder still lists two different, 3 stat kits. One before date code 51130, 28/11/05 as a 1603607 and after that date a 1603608. Now I am confused. π π₯
October 12, 2006 at 8:01 pm #191972SDR
just had another look on partfinder, there is a red tec bulletin on this dryer , if a heater vwith 2 stats fitted on appliance it must be replaced with a heater kit 1703245 from ser no 507120001 to 511299999 (29/11/2005) or a 1703595 from ser 511300001 (30/11/2005) to date. heater kit comes with stats fitted. hopes this makes sense. thing is if stats are ok that cust fitted it will still be module needed.
October 12, 2006 at 10:04 pm #191973iadom
Thanks for making that clear, I think. π
Much appreciated.
October 14, 2006 at 3:34 pm #191974Bernie
Thanks for all the information and thanks to Jim for the wiring diagram.
Going back to it on monday 16th Oct will let you know how I get on.Bernie
