Hotpoint CTD80 dryer Drum support bearing replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint CTD80 dryer Drum support bearing replacement
  • #32437
    steveshaw
    Apologies if this has been answered before, I have searched the forum back to Oct 06 (37 pages) with no success. I have a noisy dryer getting progressively noisier. Stripped it down and found one of the drum support bearings is goosed, (badly installed brass bearing bush). A direct replacement is no longer available from any web site, now being replaced by a ‘condenser bearing kit’ consisting of 4 off bearings (more like flat brackets), a belt and a rear bearing bush. Apparently no instructions are included with the spares as to how they should be fitted. Whilst I am reasonably confident I can work it out with the Dryer in bits I would appreciate any information/assistance which could be offered
    #235129
    Re: Hotpoint CTD80 dryer Drum support bearing replacement
    There is only one brass bearing and that is the rear bearing bush, it is never badly installed but fails due to the type of belt drive now fitted to these machines. The ‘stretchy’ belts put severe strain on the rear bearing leading to early failure.
    If you are referring to failure of the front drum support wheels then they have been superceded by the four bearing pads that have been fitted to Creda based machines for over 20 years.
    They will slot into the front surround after the wheels have been removed and discarded.
    PS. This is not an easy machine to work on, even for the experts, getting it back together will be an ‘experience’ for you. 😉
    helo_75
    actually jim, theres 2 different back bearings… ones square, the other one is a tear drop shape, incorporated into a new back panel
    if you need the rear bearing, and its square, u can use the vented kit (previous p/no 1703080) that has the front pads , rear bearing (square).. front and rear seals, drum shaft and a bearing pin
    not seen a lot of the teardrop bearings, but they are out there, trust me
    #235131
    I have seen a couple of teardrop bearing failures already. 😥
    Reading the OP’s post he mentioned ‘one of the drum support bearings’ as opposed to the ‘rear bearing’, which caused me to think he was referring to the front wheels.
    helo_75
    good call… at least the 1703080 kits has them all in, so thats the best option
    it still allows you to remove the wheels, and fit front pads to the machine
    #235133
    steveshaw
    Thanks for the reply’s. The brass bearing I refer to is the press in brass bush within the plastic drum support roller. At some point, either during manufacture or subsequent use the insert has deformed causing the drum to ‘chatter’ during operation as the roller is no longer concentric. I assume each of the two existing rollers are to be removed when the new parts are installed, what I would like to know is where each of the four ‘bearings are to be installed and where the belt is supposed to run
    #235134
    helo_75
    they fit in the front baffle, just above where the rollers are
    if you look where the front lip of the drum runs, ull see 4 cut out with 2 holes in them, its easy to spot when u know how, and when u get the pads, you’ll see where thy fit
    yes the wheels have to come off, and ull be amazed at how quiet it will be when theyre fitted, but its a PIG of a job getting it back together
    unplug it, and wear good quality safety gloves if your gonna attempt it
    #235135
    steveshaw
    Thanks helo_75, I have already had the machine fully stripped down due to an F-08 fault for full access to the PCB, thats how I found the problem. Forgive my ignorance, but after installation does the front of the drum locate into the four bearings? as such are the belt and Rear bearing superfluous
    #235136
    helo_75
    no the supports clip into the front grey plastic baffle, the drum then sits ON the supports
    its pretty obvious, since theholes are already there
    #235137
    steveshaw wrote: as such are the belt and Rear bearing superfluous
    I would definitely change the rear bearing, the belt is optional, it is not easy to get the old belt back on, the new one will be much harder to refit.
    steveshaw
    Thanks to all, much appreciated. New parts arive today, I will post to let you know how it goes.
    #235139
    steveshaw
    To all, Many thanks for the advice. The new parts are installed and the dryer runs like a dream…. for now!
