HI
Was wondering if anyone could tell me what the error code f-10 means on the hotpoint CTD80 dryer, as i have this flashing up on my display, and how you fix it, also i dont have a manual, does anyone know where i could get one from.
thanks
Lisa
You can get a manual by following the links in the ‘Lost Your Manual’ thread at the top of this forum.
F10 is likely to be a heater or stat fault. To verify it needs to be checked with the correct test equipment.
Please remove the mains plug if you intend to investigate yourself.
