Hotpoint CTD80 fault F15 on screen and is constant ON
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint CTD80 fault F15 on screen and is constant ON
  • #82796
    shadowcorp
    Hello, I have a hotpoint CTD80P and it was tripping the house due to a heating element issue (now fixed). but now I am getting an F15 error on the screen (that is quite dim) and when the dryer door is closed, the dryer works like it on a normal cycle (heats and spins) …even if I have not turned it on.
    how do I fix this? new top end PCB, or bottom side pcb, both, ect?
    pulling my hair out.
    #420835
    Re: Hotpoint CTD80 fault F15 on screen and is constant ON
    The main power board is faulty, expensive and needs programming.
    #420836
    shadowcorp
    can I not get one from another dryer that’s going to end of life? or is each main board and display board married by code?
    #420837
    Unless you can find one that is very near to your serial number then the chances are very remote. There are six different non interchangable versions of eeprom and the software. 😥
