HOTPOINT CTD80 Tumble dryer
  • #28545
    cornflakes
    appliance about 22 months old, Creda/hotpoint repaired under warrenty
    TOC’S failed twice.
    same fault occured out of warrenty period..client unwilling to pay HPT callout fees.
    I visited in Jan 2007..same thing no heat – 1 TOC shot it
    replaced with WHITE TOC although replaced both as per HPT instructions.
    was called mondat to same fault..same white TOC shot it
    Question I am asking:
    is there a common fault on this model to go 3 times in such a short while seems beyond reason, considering clients last T/D lasted 20 odd years, which was a Hotpoint..hence the loyalty to remain with HPT.
    or was I given incorrect TOC’S from my supplier?
    thanks
    Graham
    #218746
    petalpop
    Re: HOTPOINT CTD80 Tumble dryer
    check she is cleaning filter
    and not opening machine half way through program and then switching it straight off
    element is hot and if there is no air flow it can over heat the stat
    hense why they put a cooling down period at the end of the drying time
    #218747
    bobokines
    Several of these suffer from a faulty capacitor. It tends to be intermittent so it can be a sod to diagnose. The drum stops to reverse and then doesn’t start again causing the TOC to cut out.
    Bob
    #218748
    hotpnt
    also make sure there is no earth fault on the machine, as the cycle stat operates on the neutral, so even if it cuts out the heater can still power live-earth
    #218749
    deltra
    hi, try what bob said,replace cap 7uf i think ❗ also those white spot stats can be reset 😉
    #218750
    mowerman80
    Hi i had one of these doing the same thing and it turned out to be the timer , the drum goes into reverse then instead of going forwards it goes into reverse again causing the stats to cut out. Changing the timer fixed the problem.
    #218751
    mowerman80
    sorry pc just went nuts
    #218752
    Fixed.
    cornflakes
    thanks guys
    will change get back to the drawing board
    #218754
    mowerman80 wrote:Hi i had one of these doing the same thing and it turned out to be the timer , the drum goes into reverse then instead of going forwards it goes into reverse again causing the stats to cut out. Changing the timer fixed the problem.
    I very much doubt it, this is a CTD80 this machine does not have a timer. 😉
