Replacement heater has two stats and a thermistor, part number C00145745, front THERMISTOR is C00113822. Bear in mind this is a thermistor and not a stat so if you have tested it you may think it is faulty when in fact it is OK. I have never yet had to change a front thermistor.
Hi Jim
Thanks for your reply, but this heater has only got 2 stats on it.
The left one is a white spot TOC.
Spares listings I have looked at all list several heaters hence my confusion.
John
My post did say REPLACEMENT heater has two stats and a thermistor.
Since first production this machine has had two stats plus thermistor, then it changed to one stat and thermistor and is now back to two stats plus thermistor.
If you order that part it will come with all three and will fit.
