Hotpoint CTD80P – not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint CTD80P – not heating
  • #94714
    SteveBl
    Morning all,
    Condenser tumble dryer had an F8 error code (heater fault). Tried re-setting the thermostat but no joy. I bought and fitted a new heater element off Fleabay. Tumble dryer made noise but drum wouldn’t turn, and tripped RCD. When I turned the drum by hand, it would start turning, so capacitor must need replacing; bought, fitted and drum now turns….but no heat. New heating element must have tripped the RCD, but the thermostats are single use and can’t be re-set. New heater arrived this morning and fitted, but still no heat.
    I’ve checked connections, cleaned the machine to within an inch of its life. I have more belly button fluff than this wretched machine. Before I call someone out or buy a new machine, can anyone offer any advice, or words of comfort please?!!
    Thanks in advance, Steve.
    #458082
    Re: Hotpoint CTD80P – not heating
    from what I am seeing there seems to be 3 heater elements fitted to this range of machines. I cant say what the difference between them is but it may make a difference
    also try the machine on a timed programme to see if it heats on that and some machines will not heat unless they detect wet clothes for energy saving purposes
    when you tried it did you put wet clothes in it ?
    SteveBl
    Hi Dave,
    That’s what I thought initially, so yes, put some wet clothes in. Put it on a timed programme and it almost immediately on starting dropped the time from 2hrs to 10mins. I put a heavier load in, and on an untimed setting, and no heat on either.
    Where are the other heater elements hiding?!
    Thanks, Steve.
    #458084
    there are not 3 elements in the machine but there seems to be 3 different elements fitted depending on serial numbers
    https://shop.ukwhitegoods.co.uk/catalog … ng+Element
    you can also get the stats separately
    https://shop.ukwhitegoods.co.uk/catalog … hermostats
    which would have been a lot cheaper than the element
    SteveBl
    Apologies, mis-read your post. The one I bought is supposedly compatible with this model number, but I have e-mailed the seller to confirm. Thanks Dave.
    #458086
    what is the part number on the unit you have received ?
    the seller can confirm it fits the model but will not be able to confirm it is correct without the serial number and commercial code
    even if its wrong it still might not be the reason its not heating
    SteveBl
    The MPN is C00258828 which I’m sure is the correct part for the machine?
    #458088
    part needed depends on commercial code and serial no
    there are 3 elements listed
    C00258799
    C00260045
    and the one you have got C00258828
    all are different in some way otherwise they would be the same part number.
    SteveBl
    Fair point. On the front of the machine, there’s a sticker;
    Model CTD80P
    Serv. ref. 95313560000 703200204
    Is that enough to identify the right part, or should I be looking somewhere else?
    #458090
    SteveBl
    Model; CTD80P
    Ind. Code: 95313560000
    Serial No. 703200204
    #458091
    from those numbers correct element is
    C00258799
    SteveBl
    Thank you Dave – much appreciated. I have ordered the correct part.
