hotpoint ctd85 fault
  • #37010
    razor
    Hi all , got a hotpoint ctd85 eith a F15 fault , F15 – Dynamic heater relay with contact welded closed
    is this the module ??
    Thanks all
    #253123
    Re: hotpoint ctd85 fault
    The full list of possible causes from the error codes thread.
    F15 Dynamic (PD) heater Relay
    with NA/NC contact welded
    closed.
    – Verify efficiency of contact J4;
    – Verify at room temperature (20°C) on the J4 connector if the
    resistance between Pin 1 and 2 is 48 Ω;
    – Verify continuity between wiring between J4 and Static Heater;
    – Replace Heater;
    – Replace main board.
