Re: Hotpoint CTD85A Condenser dryer
Marstafitta wrote: The stats were replaced after cleaning everything of the fluff and dust. ( stat kit1701583)
Possibly not a master fitter 😉 😀
That is the cause of your problem, totally incorrect parts fitted.
Your machine has an NTC as well as a stat, the NTC may appear to be open circuit using a simple multimeter continuity test when it is perfectly OK.
Before serial number 51130.0000 you need part number 1702790 which has a white ELTH thermistor (NTC).
After serial number 51130.0001 you need part number 1703413 which has a black TOD thermistor.
