nope, youll need to purchase an eprom as well.. the one on your existing board simply wont fit
as usual, the eprom depends on the sensor
does it have a metal band around the drum?
might be worth taking advantage of hotpoints £89 fixed price repair, at least then that covers you for every eventuality
f05 is ‘no feedback from the pump’ so if youve changed the pump, it has to be the pcb, im afraid
as for the pcb, check the wires back from the pump to the pcb, and check for any fried connections/tracks around that area (plug out, of course)
hope this helps
