hotpoint d/ oven bd32
Viewing 15 posts - 1 through 15 (of 15 total)
  • #54079
    adv
    went to this today, oven element blown blew old style 30amp fuse in fuse box changed and fitted new element, timer works but no light and fan or heat when turn state on can here cooling fan goin tho, am thinkin main oven state blown, is probaly main cause thanks? also oven had only been on for 15 mins so dont think it over heated
    #318314
    Re: hotpoint d/ oven
    Errr…model number???????
    #318315
    don
    Re: hotpoint d/ oven bd32
    It`s in the title Jim 😉
    #318316
    don wrote:It`s in the title Jim 😉
    Of course it is now Don, but you have noticed the time of adv’s edit haven’t you. 😉
    #318317
    It could be the stat or possibly the main oven selector switch pack. Most of the time you can see signs of damage on the contacts inside the selector switch.
    Would need FULL model number and serial number to identify correct parts.
    For instance it could be a BD32B, BD32B MK2, BD32B MK2 (T) or BD32B/2.
    The B after 32 is a colour reference so that could be B,K,N or P which is not important.
    adv wrote: am thinkin main oven state blown, is probaly main cause thanks?
    In that case the stat is easy to check as it’s live in and live out! No live in means its either the TOC or most likely the contacts on the rotary switch have gone AWOL.:?
    HTH?
    #318319
    don
    iadom wrote:Of course it is now Don, but you have noticed the time of adv’s edit haven’t you. 😉
    I have now 😆
    #318320
    adv
    cheers am goin with new oven state cudnt lift it out, on own 1st visit 😆
    #318321
    Have you made sure you have the correct one, there are a few alternatives which are not interchangable apparently. Its more likely to be the selector switch in any event. 😉
    #318322
    adv
    i hope so mate you dont need to turn selector switch,.its just the thermistate you turn to put main oven on the selector switsh is to operate top oven and grill so hears hopeing am rite 😆 ive had look on connect does show selector pack s””t mmm 😳
    #318323
    You are turning the switch pack, the thermostat is mounted on the back of the main oven switch pack.
    #318324
    adv
    mmm what a bumber element took me 15 mins. too now how long to fix god nows.wat makes you think switch pack rather than the state?
    #318325
    I’ve seen it blow both but its more often the switch pack. Just checked and there are at least four different thermostats used on BD32 models. A big difference in price between them as well. 😉
    I would be following Martins advice, test the stat and visually examine the switch pack and be sure to get the full model and serial number. 🙂
    The controls are quite easy to get on these.
    #318326
    adv
    cheers a few miles out of town too typical 😳
    #318327
    adv
    wat a mare that job was, thoght ovens were easy to. changed fuse in box, fitted element, fited switch pack working put all back in , then state naw cut off, back owt an fit thermistate,. working great, thank crist, good ending tho women paid cash 😆 thanks for in put guys 😆
