Hotpoint D/W
  • #5588
    PINKY
    Good afternoon chaps,
    I’ve been out to a DF42 with the fault code E20, i know this means tempreture under range, does anyone actually know the cure? it seems to happen before you start the machine on a programme and only happens intermittantly, your knowledge is appreciated!!!
    Pinky
    #112017
    Re: Hotpoint D/W
    Pinky,
    I think it may well be a dicky Heater Relay contact on the Power Module board.(Dry joint even?) Run a soldering iron over the board terminals too will help for intermittent faults like that.
    Good luck 😆
    PINKY
    Re: Hotpoint D/W
    cheers martin I’ll check it out
