stuck with this d/w fault..customer reports not heating… checked heater resistance ..ok.. checked heater m/s…ok…inlet valve buzzing so changed that as there was only a low level of water in the machine..also changed metering tank as it was clogged ..when you run the d/w it goes through the whole cycle but never heats up.. 😕 :rolls: whats not going on?
richard
jim, thanks for offer..as you say, puzzled that it completed cycle on all programs without heating up! the last part i did change was the heater protection micro switch and it got hot! :rolls:
richard
