hotpoint d/w fdw60
  • #19110
    robbo1973
    hi the fault is the eco and fast wash leds are flashing i have looked in error codes and it says timer/hardware does this mean a new board 😥 also i take it you do not count the rinse aid led as a fault led. many thanx chris
    #181777
    Re: hotpoint d/w fdw60
    Neons 1 & 2 flashing can mean software recognition error, but can also mean timeout draining ( blocked pump) a more common fault than software fault.
    robbo1973
    the neons flashing are 3 and 4 which relates too hardware failure not 1 and 2.pump running and emptying fine.
    #181779
    I see, I don’t have a manual on that model so I cannot match up the neons, using the neon numbers is always the best way as the options vary from model to model.
    Does look as though you may have a software error. 😥
