hotpoint d/w fdw60 error code lights 4 and6
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint d/w fdw60 error code lights 4 and6
  • #57468
    clockworkone
    hi went to d/w today, fills with water then nothing.has to be emptied by hand. lights 4 and 6 flashing(heater fault)have checked heater giving a reading 0f 26/27 ohms so seems ok.are all stats built into heater or have i missed one .have noticed in forum that pcb can be a problem on these.any advice would be gratefully appreciated.paul
    #331153
    A1engineer
    Re: hotpoint d/w fdw60 error code lights 4 and6
    there should be a screw in stat at back right of base, however pcb is most likely fault.
    #331154
    clockworkone
    thanks for that, think you are right. is there a reprogramming procedure with these or is it just straight swop.p
    #331155
    A1engineer
    straight swap, when you 1st plug it in its in test mode but there is a sheet to explain how to reset it etc.
