comes up with fault al05 which is circ pump
run and tested machine and motor runs smooth and quiet
apparantly only does it 1 out of 10 runs
any ideas guys
The pump is routed through the main motor on certain models. If the motor overheats after heavy use or very hot washes the motor overload will trip and cut out the drain pump as well.
On the one I had it always worked again when left overnight.
that would make sense
she said it was stuck full of water when the fault showed
and even after clearing the fault it didn`t pump out
but then worked fine when i got there and tried it
