hotpoint dc26 dishwasher
  • #7074
    Tom
    Does anyone know if there is a reset procedure for this machine?
    Its behaviour is not consistent;
    The customer reported that it was not going to the rinse, but I cannot get it to proceed with the wash every time. It doesnt take in water but the circulation pump is running. The control module has been checked by QER and no fault found. The inlet valve has checked OK.
    Any help will be much appreciated.
    tom
    #121269
    Dave_Conway
    Re: hotpoint dc26 dishwasher
    Holding two of the buttons (not sure which two though 😕 ) will reset the PCB.
    It sounds more like the float switch on the air break is at fault or possibly the pressure activated microswitch on the heater chamber.
    #121270
    Dave_Conway wrote:Holding two of the buttons (not sure which two though 😕 ) will reset the PCB.
    That’s the 2nd(Normal 65) and 4th(Quick35) Buttons press together for 3 seconds to reset 😉
    As Dave suggests, go for the Pressure switch Unit first, the hose to the tank then check the heater (In that order really) :tup:
    Fingers crossed eh?
    clivejameson
    …and check the metering tank to sump hose too, this often partially blocks
    Clive
